[Qgis-developer] Re: [Qgis-user] [Fwd: Binary QGIS 1.2.0.2~jaunty + GRASS does not work]
Agustin Lobo alobolistas at gmail.com
Fri Sep 11 15:38:45 EDT 2009
Jürgen E. Fischer wrote:
> On Fri, 11. Sep 2009 at 13:55:42 +0200, Agustin Lobo wrote:
>> In grass
>> r.in.gdal -o
>> input=/media/Transcend/ANYELLA/catuav20090730/tif/SDIM0178.tif
>> output=delmetif
> That's the wrong direction.    You need to access GRASS from GDAL not vice
> versa.
> gdalinfo $HOME/grass/spearfish60/PERMANENT/cellhd/elevation.10m
I think the problem is in gdal:
$ gdalinfo
/media/Transcend/MONTSENY2008/Carlos_Montseny/GrassData/GrassData/carlos/A_TOTAL/cellhd/delmetif.blue
Segmentation fault
> That's strange.  Try
>  apt-cache rdepends libgdal1-1.5.0
> to see what depends on libgdal1-1.5.0.  There shouldn't be anything qgis or
> grass related except for libgdal1-1.5.0-grass.
$ apt-cache rdepends libgdal1-1.5.0
libgdal1-1.5.0
Reverse Depends:
  python-mapscript
  php5-mapscript
  perl-mapscript
  mapserver-bin
  libmapscript-ruby1.9
  libmapscript-ruby1.8
  libmapnik0.5
  cgi-mapserver
  python-mapscript
  python-gdal
  php5-mapscript
  perl-mapscript
  mapserver-bin
  libopenscenegraph7
  libmapnik0.5
  libgdal1-dev
  libgdal-ruby1.8
  libgdal-perl
  libgdal-doc
  grass
  gdal-bin
  cgi-mapserver
The weird thing is that according to Synaptic libgdal1-1.5.0-grass is
not installed
(I removed it with apt-get remove after installing the qgis-grass-plugin)
How can I check with apt if libgdal1-1.5.0-grass is installed or not?
> And try
>  apt-cache depends qgis-plugin-grass
> to see what qgis-plugin-grass depends on.  There should only be the dependency
> to one of the libgdal1-*-grass packages - and that should be satisfiable by
> installing libgdal1-1.6.0-grass.
$ apt-cache depends qgis-plugin-grass
qgis-plugin-grass
  Depends: qgis
  Depends: qgis-plugin-grass-common
  Depends: libc6
  Depends: libgcc1
  Depends: libgdal1-1.6.0
  Depends: libgeos-c1
  Depends: libproj0
  Depends: libqgis1.2.0
  Depends: libqt4-network
  Depends: libqt4-sql
  Depends: libqt4-svg
  Depends: libqt4-xml
  Depends: libqtcore4
  Depends: libqtgui4
  Depends: libstdc++6
 |Depends: <libgdal1-1.4.0-grass>
 |Depends: libgdal1-1.5.0-grass
  Depends: libgdal1-1.6.0-grass
it depends on bot libgdal1-1.5.0-grass and libgdal1-1.&.0-grass ?
Thanks for your help!
Agus
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090911/296e0961/alobolistas.vcf
