[Qgis-developer] Qgs Canvas API
Jürgen E. Fischer jef at norbit.de
Tue Aug 3 07:24:12 EDT 2010
Hi Martin,
On Tue, 03. Aug 2010 at 13:12:38 +0200, Martin Dobias wrote:
> > 1) Which type of installation I must doing if I want to be able to use Qgs
> > API? Current version? Trunk Builds? Source code and than compile it?
> If you're going to use Python, things are simple. You can use QGIS
> from standalone installer or from OSGeo4W. When using C++ I think you
> will have to compile QGIS from source to have the access to the
> libraries and headers.
No, the OSGeo4W and the debian packages contain the libraries and headers.
> > 2) Can I developing my application on Windows 7 64 bit architecture?
> I think there shouldn't be a problem.
OSGeo4W is 32bit - so if you're going to build C++ plugins on Windows 64bit you
probably really need to build QGIS and depencencies from source.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
