[Qgis-developer] PostGIS plugins menu
John C. Tull jctull at gmail.com
Mon Aug 16 11:02:37 EDT 2010
On Aug 15, 2010, at 2:59 AM, Borys Jurgiel wrote:
> My suggestion for now is to put everything to a PostGIS submenu within the Plugins menu:
> self.iface.addPluginToMenu('PostGIS', actionBlahBlah)
> Then we can modify the QgsInterface.addPluginToMenu method to put each submenu either to the Plugins branch or to the main menu, so each user can configure which plugin sumbenus are at hand. It's a five-minuts-fix to read it from QSettings (still without any GUI for configuring it, but it's a step forward).
+1
> The third step is the GUI. I started refactoring the Installer (just three hours per month, so it's why no changes are commited) and with Martin and Anne we plan to put it as a second tab of the manager. What about a third tab "menus and toolbars", when an user can be able to:
> 1. Select whether given submenu (e.g. PostGIS) goes to the main menu or the Plugins menu
> 2. Select whether given submenu creates its own toolbar or goes to the main Plugin toolbar.
> 3. Compose own toolbar(s) with a set of individual plugin buttons. It allows to hide the native plugin toolbar and enable personalized ones, like "Monday's tasks", "Tools useful for X-files processing etc"
> 4. Save/load profiles (at least sets of plugins to be loaded - now I often have to use --noplugins option to make qgis faster)
> What do you think? The first two steps can be done in a moment.
+1 for each of these ideas also
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100816/82fb4301/attachment-0001.html
