[Qgis-developer] Profile from contours
Craig Leat craig.leat at gmail.com
Thu Aug 19 11:40:44 EDT 2010
I wish to generate a terrain profile from vector contours directly
without having to interpolate a raster DEM first. Does anyone have
such a plugin on the cards for development?
ArcView 3.x has a tool called "Easy Profiler2.1" with source code in
the public domain [1].
I initially thought interpolation could be avoided by only extracting
heights from intersection points between the path and contours, but
soon realised the path distance is under estimated if one assumes a
straight path between intersection points.
Regards,
Craig
[1] http://arcscripts.esri.com/details.asp?dbid=11606
