[Qgis-developer] PostGIS plugins menu
Tim Sutton lists at linfiniti.com
Sat Aug 21 04:45:38 EDT 2010
Hi
+1 to put them under a plugins->database menu
Perhaps merging some of the plugins to provide a 'super postgis'
manager plugin would also be worth thinking about?
Regards
Tim
On Thu, Aug 19, 2010 at 2:10 AM, Giuseppe Sucameli
<brush.tyler at gmail.com> wrote:
> Hi all,
> On Wed, Aug 18, 2010 at 10:05 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Borys
>> On Sun, Aug 15, 2010 at 11:59 AM, Borys Jurgiel <borysiasty at aster.pl>
>> wrote:
>> > My suggestion for now is to put everything to a PostGIS submenu within
>> > the
> > Plugins menu:
>> > self.iface.addPluginToMenu('PostGIS', actionBlahBlah)
>> Right. I will do that for postgis manager in the next release.
> I moved all my 2 PostGis plugins (rt_sql-layer e rt_postgres-extractor)
> to the PostGIS menu:
> self.iface.addPluginToMenu('&PostGIS', self.action)
>> > Then we can modify the QgsInterface.addPluginToMenu method to put each
>> > submenu either to the Plugins branch or to the main menu, so each user
>> > can
>> > configure which plugin sumbenus are at hand. It's a five-minuts-fix to
>> > read
>> > it from QSettings (still without any GUI for configuring it, but it's a
>> > step
>> > forward).
>> > The third step is the GUI. I started refactoring the Installer (just
>> > three
>> > hours per month, so it's why no changes are commited) and with Martin
>> > and
>> > Anne we plan to put it as a second tab of the manager. What about a
>> > third
>> > tab "menus and toolbars", when an user can be able to:
>> > 1. Select whether given submenu (e.g. PostGIS) goes to the main menu or
>> > the
>> > Plugins menu
>> > 2. Select whether given submenu creates its own toolbar or goes to the
>> > main
>> > Plugin toolbar.
>> > 3. Compose own toolbar(s) with a set of individual plugin buttons. It
>> > allows
>> > to hide the native plugin toolbar and enable personalized ones, like
>> > "Monday's tasks", "Tools useful for X-files processing etc"
>> > 4. Save/load profiles (at least sets of plugins to be loaded - now I
>> > often
>> > have to use --noplugins option to make qgis faster)
>> > What do you think? The first two steps can be done in a moment.
>> I like this idea of giving the users a chance to override the default
>> placement. I would like to go even further - to allow user to
>> manipulate individual actions created by the plugins - but that would
>> probably need an addition to interface API (otherwise the
>> identification of actions would depend on their name in current
>> translation). I think of showing a tree widget to the user where nodes
>> would be menus and submenus, the leafs would be individual actions.
>> The user would be able to modify the tree in any way he likes: add new
>> top level menus with some actions or just reorganize the 'Plugins'
>> menu.
>> If we end up updating the plugin interface, we could also proceed with
>> defining the categories as we have discussed at the hackfests. Each
>> plugin would be _strongly_ advised to suggest a category where it
>> belongs, so ideally the users will not have to organize the plugins
>> manually.
> +1, would be great!
> Cheers
> Giuseppe Sucameli
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
