[Qgis-developer] Enchancing New Symbology - ColorRamp Edit
Noli Sicad nsicad at gmail.com
Sun Aug 22 04:01:07 EDT 2010
Hi Benoit,
NO. I have not since I am working mostly on vector and databases.
I am installing it now.
 Any sample data and tutorial how to use it?
Could this plugin be replicate into a new plugin for vector files and
spatial databases.
Thanks.
Noli
On 8/22/10, Benoit EXIGE <benoit at exigesa.com> wrote:
> Hi Noli,
> Did you have a look at the 1-band raster colour plugin?
> I've posted it in the QGIS repository. It is flagged as experimental
> so you will have to enable experimental plugin in the plugin manager.
> I think it will respond to what you are looking for.
> Cheers,
> Benoit
> On 22 Aug 2010, at 3:24, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>> It seems that QGIS has only 3 color ramps, probably we can improve it
>> by adding more options and increase the class size as well.
>> http://www.qgis.org/wiki/Symbology_RFC#Python_plugin
>> Where is the "Color ramp dialogs"? Is this implemented?
>> I find color ramps in R package quite flexible especially using ssplot
>> for thematic mapping. Color Brewer is quite limited.
>> ColorRamps
>> http://bm2.genes.nig.ac.jp/RGM2/R_current/library/IDPmisc/man/IDPcolorRamp.html
>> http://cran.r-project.org/web/packages/colorRamps/colorRamps.pdf
>> Now, how can we hack QGIS 1.5 to add more color ramps pallete
>> Arcgis is also using color ramps.
>> ArcMap Edit color ramp
>> http://www.tectonics.caltech.edu/gis/reference/color_ramp.html
>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
