[Qgis-developer] Help: C++ Plugin Devt Procedure
Tim Sutton lists at linfiniti.com
Tue Aug 24 06:14:47 EDT 2010
Hi
The simplest way to do it is probably just to create your plugin
within the QGIS code tree (under /src/plugins). Assuming you have a
working QGIS build environment, building your own plugin then shouldnt
present any hassles.
Regards
Tim
On Tue, Aug 24, 2010 at 5:36 AM, M Nazari (gmail) <mnazari2020 at gmail.com> wrote:
> Hi everyone,
> I am new at QGIS Plugin development.  I have been wrestling with C++ plugin
> development - have tried Visual C++ but have all sorts of difficulties.  It
> compiled OK but it failed to carry qgis_core dependencies. Compiled it
> different way, qt_wrap_ui or something is the error.
> Straight to the point - do we have a "step-by step" plugin development
> document? I have tested the one in the guidelines - but I guess it is
> outdated or it could be me(?).
> This novice QGIS plugin writer desperately needs some pointers.
> Thanking you in advance,
> Nazari Jaafar
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
