[Qgis-developer] QGIS build with GDAL 1.7.x - Ubuntu
Jürgen E. Fischer jef at norbit.de
Sat Aug 28 03:53:33 EDT 2010
Hi Noli,
On Sat, 28. Aug 2010 at 14:51:29 +1000, Noli Sicad wrote:
> It seems that QGIS trunk builds is still building using GDAL 1.6 as of
> 27 August 2010.
The builds are simply using the GDAL the distribution has.  As far as I can
see only ubuntugis currently has GDAL 1.7.   That will eventually change and
once it does the nightly builds will pick it up.
You can always build you own packages - with is particulary easy on debian (and
ubuntu).   Install GDAL 1.7 from ubuntugis (or experimental - in the debian
case) and [1]
Jürgen
[1] http://www.qgis.org/wiki/Installation_Guide#Building_Debian_packages
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
