[Qgis-developer] QGIS build with GDAL 1.7.x - Ubuntu
Noli Sicad nsicad at gmail.com
Sat Aug 28 05:40:16 EDT 2010
Hi Juergen,
Thanks for your suggestion in compiling from the source.
However, I investigated your QGIS 1.5.0.2 built and this one is
actually build with libgdal1.7.0.
I installed it and it is actually using GDAL 1.7.2 and Spatialite 2.4.0
But I could not open any spatialite that I created and also the
spatialite file (subway_test.sqlite) found in this website below.
http://gothos.info/2010/02/calculated-fields-in-spatialite-sqlite/
This is very strange bug. "nyc_pumas" (Geometry is an invalid layer
and cannot be loaded).
William's Mac OS X QGIS - QGIS-dev does not have this bug.
I will try to see what is inside that that built before compiling one.
He just did the compiling last weekend.
Thanks.
Regards, Noli
On 8/28/10, Jürgen E. <jef at norbit.de> wrote:
> Hi Noli,
> On Sat, 28. Aug 2010 at 14:51:29 +1000, Noli Sicad wrote:
>> It seems that QGIS trunk builds is still building using GDAL 1.6 as of
>> 27 August 2010.
> The builds are simply using the GDAL the distribution has.  As far as I can
> see only ubuntugis currently has GDAL 1.7.   That will eventually change and
> once it does the nightly builds will pick it up.
> You can always build you own packages - with is particulary easy on debian
> (and
> ubuntu).   Install GDAL 1.7 from ubuntugis (or experimental - in the debian
> case) and [1]
> Jürgen
> [1] http://www.qgis.org/wiki/Installation_Guide#Building_Debian_packages
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
