Il 02/12/2010 11:40, Milo van der Linden ha scritto: > I am trying to open a DXF file as layer, qGIS simply crashes. Starting > qGIS from the commandline gives me the following error: Have you added the path to the output shp? it crashes if not, there is an open bug on this. -- http://www.faunalia.it/pc
