[Qgis-developer] QGIS Mapserver on Mac OSX error (wiki)
William Kyngesburye woklist at kyngchaos.com
Sat Dec 4 17:43:35 EST 2010
Thanks for updating the wiki, I completely forgot after the QGIS 1.6 release.
On Dec 4, 2010, at 3:45 PM, Patrice Vetsel wrote:
> Hi,
> I'v tried the wiki :
> http://www.qgis.org/wiki/QGIS_mapserver_tutorial#Mac_OS_X
> I'v made some corrections, but the last big problem is that, with the qgis-mapserver.conf, apache can't be succesfully launched.
> I had to comment out the FastCgiConfig line.
It should work with this line.  This sets some reasonable values for the fastcgi parameters, and the defaults may not work well for a mapserver process that needs more time to do its thing.
You should check if there are any errors when Apache tries to start that would help figure out why it won't start.  The Apache logs might have something if it's a configuration error: /var/log/apache2/error.log.
A binary problem might show up in /Library/Logs/CrashReporter.
> Doing this i get a :
> "Service not specified. The SERVICE parameter is mandatory" on http://localhost/qgis-mapserv/qgis_mapserv.fcgi
> I don't know if this message tell me that qgis-mapserver is working or not.
The wiki tried to interpret the URL text in the example as a real link, and you need to make sure to include that trailing '?' that is after the link icon.
> Help is wanted to finish this tutorial :)
> Regards_______________________________________________
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
