[Qgis-developer] Edit UI doesn't load the field's value
Giuseppe Sucameli sucameli at faunalia.it
Mon Dec 6 12:32:18 EST 2010
Hi all,
it seems there is a problem with Edit UI dialog.
I have an .UI which contains a combobox and a spinbox.
When I edit a row using the Edit UI dialog, the combobox PROVINCIA loads
all the values of the PROVINCIA field, but doesn't select the current row
value.
The spinbox does the same, it doesn't load the current value.
If I use lineedits instead, it works and loads the fields' value.
Loading only doesn't work, because if I change the value and and press OK
the dialog stores the new value back into the field.
Does anybody confirm??
Cheers.
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101206/1dee1789/attachment.html
