[Qgis-developer] Delimited text plugin crash and patch
Chris Crook
ccrook at linz.govt.nz
Sat Dec 11 13:56:33 EST 2010
Hi All
I've submitted a patch for the delimited text plugin to fix an issue raised on the qgis-user list, where QGis is crashed by the plugin when it reads text files in which some rows have missing fields (common if the last fields are null/blank).
The patch fixes this by adding blank fields to deficient rows.
The patch is http://trac.osgeo.org/qgis/ticket/3320
If this looks Ok could it be committed?
Also I've submitted a patch relating the delimited text plugins to fix a corruption of the datasourceUri in the project file when the project is using relative paths and the delimiter contains "\" characters. Would be good to have this applied to :-)
Thanks
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
