[Qgis-developer] Remove geoprocessing plugin?
Tim Sutton lists at linfiniti.com
Mon Dec 13 04:06:43 EST 2010
+1
And other candidates to recieve the axe:
 - quickprint
 - copyright (you can just add an annotation)
Regards
Tim
On Mon, Dec 13, 2010 at 9:56 AM, kimaidou <kimaidou at gmail.com> wrote:
> +1 too
> Kimaidou
> 2010/12/12 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>> Hi Martin
>> +1 for removing.
>> Marco
>> Am Sonntag, 12. Dezember 2010, um 17.59:16 schrieb Martin Dobias:
>> > Hi all
>> > there is an old geoprocessing (c++) plugin in the sources
>> > (src/plugins/geoprocessing). I've found out that it has been disabled
>> > for several releases (it disabled in qgis 1.0, probably even earlier)
>> > and has just basic functionality for creating a buffer for a PostGIS
>> > layer. It seems to be unmaintained and given that there is fTools
>> > plugin which implements this functionality, I think it should be safe
>> > to remove the code from trunk.
>> > Any objections?
>> > Regards
>> > Martin
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
