[Qgis-developer] Native SQL Anywhere plugin+provider contributed
to trunk
Tim Sutton
lists at linfiniti.com
Wed Dec 22 14:10:18 EST 2010
Hi Dave
Just getting around to test driving the new provider.
What is the correct value for 'servername' in the dbisql gui (assuming
having followed your instructions below and that the database I
created is called 'gis').
Thanks
Tim
On Thu, Dec 16, 2010 at 12:00 AM, <Dave.DeHaan at sybase.com> wrote:
> Hello QGIS Devs,
> As per discussion on qgis-psc a couple of weeks ago, I have just
> contributed (rev. 14918) a native plugin+provider for Sybase SQL Anywhere
> (trunk/qgis/src/plugins/sqlanywhere; trunk/qgis/src/providers/sqlanywhere),
> similar in functionality to the PostGIS and SpatiaLite providers. Due to a
> legal technicality, this code needed to be released under GPL v3 rather
> than the usual GPL v2 used by the rest of the QGIS project.
> I've tested the code under both Ubuntu 10.04 (gcc) and Windows XP (MSVC
> 2008). If there are developers out there on other platforms, could you
> please let me know if the plugin fails to either compile or load on your
> platform (loading it should add a toolbar button and a couple menu
> options)?
> If anyone is interested in taking the plugin/provider for a test drive,
> here is a quick set of steps to get you started:
> 1. Download the free Developer's Edition of SQL Anywhere 12.0.0 here:
> http://www.sybase.com/detail?id=1016644
> 2. Install the SQL Anywhere 12.0.0 engine on your database host
> 3. Install the SQL Anywhere 12.0.0 client libraries on your QGIS client
> (only necessary if client and host are different machines)
> 4. Use 'dbinit my_database_name' to initialize a blank database on the
> host. The default user/password is initialized to 'dba'/'sql'.
> 5. Use 'dbsrv12 my_database_name' to start the database server on the
> host.
> 6. Populate the database with sample spatial data. To facilitate this
> step, I have contributed the SQL script
> src/providers/sqlanywhere/load_alaska_shapes.sql which loads the Alaska
> VMap0 shapefiles into new tables. Use the 'Interactive SQL' tool (dbisql)
> on the database host to open/execute this script (you will need to modify a
> few variables at the top of the script to tell it where to find the
> shapefiles, which are assumed to be on the filesystem of the database
> host).
> 7. Start up QGIS, and load the SQL Anywhere plugin. This will add a
> button to the data sources toolbar, as well as the menu entries 'Plugins->
> SQL Anywhere' and 'Layer->Add SQL Anywhere Layer...'
> 8. Adding a SQL Anywhere layer should invoke a dialogue box for choosing
> a connection and searching the database schema for geometry columns
> (similar look/feel/functionality to the PostGIS and SpatiaLite toolbar
> buttons). If you instead receive a message box, it means that it can't
> find the SQL Anywhere client libraries installed in step 3 (or step 2 if
> client=host).
> Please let me know if you have any questions/comments/suggestions/bugs...
> Thanks,
> Dave
> David DeHaan
> SQL Anywhere Research and Development
> Sybase iAnywhere
> ddehaan at sybase.com
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
