[Qgis-developer] Qgis crashing on QgsVectorLayer committedFeaturesRemoved signal..
Chris Crook ccrook at linz.govt.nz
Wed Dec 22 16:23:32 EST 2010
Hi All
I'm having a problem with Qgis crashing on the committedFeaturesRemoved signal in my MemoryLayerSaver plugin.  This seems to happen with the
I've raised a Trac ticket, 3366, for this.  Wondering if anyone has any insights into what could be causing this, or how to debug it.
Thanks
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
