[Qgis-developer] Re: QGIS.pro, Qt Creator and Android - Qt Creator Integration
Noli Sicad nsicad at gmail.com
Wed Dec 29 23:18:58 EST 2010
OK. I managed to install cmake package.
But still I don't what should be in the Qgis.pro after I created this project?
Anybody can post what should be in entries in Qgis.pro?
Noli
On 12/30/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> I am trying to create a Qgis.pro (i.e. QGIS Qt Creator Project) based
> on this instruction [1].
> I am stuck on this step 3.
> 3. Run cmake in CMake Wizard. You can run it after adding project for
>    this you should navigate to cmake build directory it is qtcreator-build
> in
>    project root and run ccmake .. like usually);
> There are a lot of cmake files in the cmake directory, which one should I
> use?
> Anyway, anybody has exciting Qgis.pro (Qt Creator project) already and
> like to share it.
> I like to try to compile Qgis in Qt - Android lighthouse and see what
> happen.
> You watch the video on Android - Qt Creator Integration here - Video.
> http://code.google.com/p/android-lighthouse/wiki/QtCreatorIntegration
> Anybody interested in QGIS mobile for Android?
> Thanks. Noli
> [1] http://www.osgeo.org/pipermail/qgis-developer/2009-October/007832.html
> Using QtCreator with QGis is easy. To open QGis in it you should do:
>    1. In menu File->Open File or Project (Ctrl+O);
>    2. In open file dialog find CMakeLists.txt in the root of QGIs
>    (/usr/local/src/qgis_trunk/CMakeLists.txt) and open it;
> in
>    4. After that QtCreator adds the new project with name qgis-1.x.x.
>    5. If you need to correct cmake options you can do it now (see 3);
>    6. Compile QGis (Ctrl+B);
>    7. Switch to tab Projects. In section Build Settings->Build Steps push
>    Details button and add in Additional arguments: install.
>    8. In section Run Settings push +Add and select in combo box Custom
>    Executable then push Details and add in Executable:
>    /patch/to/qgis/executable (/usr/local/bin/qgis);
>    9. Start Debugging QGis: F5.
