[Qgis-developer] Openlayers plugin issue
Mathias Walker mwa at sourcepole.ch
Wed Feb 24 04:26:25 EST 2010
Hi Marco
> > The custom SRS should have the following Proj4 config:
> > +proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137
> > +units=m +no_defs
> What is the epsg id of this srs? I'd like to include it to srs.db to have
>  it available by default.
OpenLayers calls the Spherical Mercator projection EPSG:900913. It should be
equivalent to the deprecated EPSG:3785 (http://www.epsg-
registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::3785) which became EPSG:3875
(http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:crs:EPSG::3857), but
in fact they are not exactly the same.
OpenLayers EPSG:900913 (http://trac.openlayers.org/wiki/SphericalMercator):
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
+units=m +nadgrids=@null +no_defs
When setting up a QgsCoordinateReferenceSystem with this definition it returns
the following Proj4 definition (which is used by the plugin):
+proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137 +units=m
+no_defs
EPSG:3785 is already available in QGIS as:
+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs
When using EPSG:3785 as project SRS there is a huge offset to the south of the
reprojected data relative to the Google map.
It is confusing why EPSG:900913 and EPSG:3785 are not the same, although it is
very often claimed they are identical.
To include it in the srs.db, it's probably best to use the inofficial EPSG id
900913 for the Spherical Mercator projection. This would be at least
consistent with the OpenLayers definition.
Best regards
Mathias Walker
Sourcepole -  Linux & Open Source Solutions
Elestastr. 18   7310 Bad Ragaz  Switzerland
Tel: 081 330 77 11       Fax: 081 330 77 12
mwa at sourcepole.ch  http://www.sourcepole.ch
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100224/0167c653/attachment.bin
