[Qgis-developer] Fedroa 12 and new version of qt
Jürgen E. Fischer jef at norbit.de
Fri Feb 26 07:14:46 EST 2010
Hi Micha,
On Fri, 26. Feb 2010 at 14:06:06 +0200, Micha Silver wrote:
> And Now qgis segfaults. This is a self compiled 1.4.0 installation. When
> I try to recompile the error is:
>   [  7%] Building CXX object
> src/core/CMakeFiles/qgis_core.dir/moc_qgsapplication.cxx.o
> /home/micha/Download/qgis-1.4.0/build/src/core/moc_qgsapplication.cxx:14:2:
> error: #error "This file was generated using the moc from 4.5.3. It"
Did you try that from a fresh build directory?   Looks like you didn't - or you
are still using an the 4.5.3 moc, but new 4.6.2 libraries (check with moc -v).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
