[Qgis-developer] set plugin enabled by default
Borys Jurgiel borysiasty at aster.pl
Sun Feb 28 17:48:48 EST 2010
Dnia niedziela, 28 lutego 2010 o 23:22:56 Paolo Cavallini napisał(a):
> Giovanni Manghi ha scritto:
> > as far as I can see since qgis 1.4 python plugins are immediately
> > activated after installation.
> BTW: the post-installation message should be modified then
Isn't it modified in your installation? The installer 1.0.8 should just confirm
succesfull installation. If you have an older version, Qgis 1.4 should warn
about an obsolete installer.
