[Qgis-developer] GPS feature
John C. Tull john.tull at wildnevada.org
Fri Jan 8 19:48:52 EST 2010
The gui is working now. Thanks for your work on that today. Unfortunately, no ports are being picked up on OS X. This has always been a problem with the gps plugin, so there is a mutual issue for your new feature and that plugin.
There must be some qt code that works on all platforms because other qt-based projects reportedly work on multiple platforms, including OS X. Perhaps a solution can be found from this one:
http://gebabbel.sourceforge.net/
Here is an older bug report on the gps plugin I filed:
http://trac.osgeo.org/qgis/ticket/1170
Cheers,
John
