[Qgis-developer] Web mapping framework?
Germán Carrillo carrillo.german at gmail.com
Fri Jan 15 20:29:41 EST 2010
Hi Zoran, maybe you can find useful a basic comparison between web map
clients.
So visit:
http://geotux.tuxfamily.org/index.php?option=com_myblog&task=view&id=239&Itemid=59&lang=en
The comparison is originally in spanish. The english translation is finished
( but under revision :) ).
Germán
2010/1/15 Zoran Jankovic <zoran.jankovic at zisis.hr>
> On Thu, Jan 14, 2010 at 9:58 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi Zoran,
>> For the client part I would recommend any of (or a combination of)
>> OpenLayers/GeoExt/MapFish. All three are related.
>> For the Server either UMN Mapserver or Geoserver is fine. There is also a
>> QGIS mapserver developed by Marco Hugentobler. Marco will work on it later
>> this year so you can re-use .qgs project files for web projects (without
>> having to write other config files). Meanwhile you can already use QGIS
>>  mapserver, but you have to write an SLD. It will serve the data as WMS. UMN
>> and Geoserver are certainly more tested and perhaps faster than the current
>> QGIS mapserver.
>> Marco can tell you more about QGIS mapserver.
>> Andreas
> Thanks Andreas,
> This QGIS mapserver sounds promising, I'll look into this. As I said speed
> is not my primary concern now, but simplicity and "looks"...
> Anyone here with working experience with Fusion? They seem to be much more
> concentrated on MapGuide, not Mapserver? But that's a question for some
> other mailing list...
> I'm still interested in hearing from anyone willing to share his/her
> experience... (QGIS + Mapserver...).
> BR,
> Zoran Jankovic
> ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
> Consulting
> http://www.zisis.hr
> M: 00 385 98 682 902
> T:  00 385 44 683 374
> A. Senoe 4
> 44320 Kutina
> Croatia
> Qgis-developer mailing list
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100115/b3ec4342/attachment.html
