[Qgis-developer] Re: SVGFill test
Marco Hugentobler
marco at hugis.net
Sat Jan 16 14:42:32 EST 2010
Hi John
Could you send me the svg file you used and a small test dataset where the
problem happens? Like that, I could check if it works on my system or not.
The svg files I tested so far worked (but not all 100% correct, probably
because of the Qt SVG classes).
Regards,
Marco
Am Samstag, 16. Januar 2010 19.25:54 schrieb John C. Tull:
> Hi Marco,
> I am quite interested in the progress you are making with the composer. I
> tested the newly added svgfill a moment ago on my OS X system.
> Unfortunately, despite changing the outline color to yellow and providing
> an svg symbol for the fill, the layer remains unfilled and with a black
> outline. I tested this on my ubuntu vm also, and no luck there either. I
> am guessing this is a work in progress and I may be jumping the gun.
> Otherwise, I must be doing something incorrectly or it is broken.
> Cheers,
> John
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Webereistr. 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis/
Technical Advisor QGIS Project Steering Committee
