[Qgis-developer] OSX Xcode python compilation update, small config change
John C. Tull john.tull at wildnevada.org
Sat Jan 16 17:34:04 EST 2010
Oops, was meant for the list also. Thanks
Martin, is there a specific setting for cmake or are these speedups automagic?
Cheers,
John
On Jan 16, 2010, at 2:29 PM, William Kyngesburye wrote:
> (meant to go to list?)
> Note that part of the speedup is from Martin and applies to cmake build (and he said something about an option that does parallel compilation in cmake, like Xcode does).
> On Jan 16, 2010, at 3:38 PM, John C. Tull wrote:
>> Great work everyone! Might be time to quit cmake builds, except for bleeding edge updates between William's xcode project fixes.
>> On Jan 16, 2010, at 11:24 AM, William Kyngesburye wrote:
>>> The xcode project is updated to handle the new python module compilation (thanks Martin!).  It compiles faster - from the new compilation process from Martin, and now the sources are compiled by Xcode instead of by the old python script so they can take advantage of Xcode's multithreading.
>>> A new addition to the Xcode configuration - PYQT_SIP_DIR and PYQT_SIP_FLAGS.  These are set by default to SIP+PyQt (Carbon) installed for the system Python as described in the INSTALL doc.  They may need to be adjusted (manually) for other configurations.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
