[Qgis-developer] Zip Layers Plugin
Luiz Motta motta.luiz at gmail.com
Fri Jan 22 08:30:35 EST 2010
Giovanni,
Thanks for  evaluate the plugin.
Answers for your comments
a) OK.
This error appers when source is shapefile and do not have selected
features.
I do not check if  shapefile have PRJ.
Corrected bug!
b) It is needed because the user can click "create button" again when
process  is running.
I believe the zip operation is made only once
c) I changed UI for resize
New version 0.1.1
Giovanni Manghi escreveu:
> Olá Luiz,
> nice works as always.
> Just a few notes:
> a) if the vector is a shape and the .prj file is not available then the
> plugin throws a pyhton error "OSError: [Errno 2] No such file or
> directory: '/home/gio/Desktop/penela/mat_base/cart_2/vector.prj'
> b) once a zip is created the button "create zips" become not available
> to be be clicked again
> c) under linux (ubuntu), in the UI, the "description layer" window is a
> little higher than the "vector layers" window. It would be good also to
> let the user resize the UI at least horizontally to improve the reading
> of the infos in the "description layer" window.
> thanks!
> -- Giovanni --
> On Fri, 2010-01-22 at 01:13 -0200, Luiz Motta wrote:
>> Hi all,
>> I post the plugin "Zip Layers", site of User-Contributed Python Plug,
>> this plugin create zipfiles from
>> layers of  Layers/Legend in QGIS.
>> Each zipfile is a shapefile of one layer.
>> The layer is not necessary be in shapefile format.
>> I tested with a spatialite source, where, the BLOB field was saved how
>> text field.
>> I believe if have the field not supported by shapefile provider(OGR),
>> this will be created how text field.
>> I would like testing the datetime field from layer in Postgresql/Postgis.
>> Please, someone can test this case.
>> Best regards,
>> Luiz Motta
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
