[Qgis-developer] Plugin Georeference handle files with existing georeferencing information
Manuel Massing m.massing at warped-space.de
Tue Jul 13 06:43:31 EDT 2010
Hi Luiz,
> > Add GCP's, in this case, i get the maps coordinate with same projection
> > of original image (geotif).
I just realized that you seem to work with GCPS specified in the input
coordinate system (at least if I understand your workflow correctly, you enter
seem to enter GCP coordinates in the original coordinate system?).
Reprojecting the GCPs to another SRS will hopefully be supported soon (see
#787) from within the plugin.
