[Qgis-developer] QGIS 1.5 Branch is done - Call for Packaging
Germán Carrillo carrillo.german at gmail.com
Sun Jul 18 18:46:46 EDT 2010
Hi all,
I've just installed the new QGIS version, thanks for all that work and kudos
for the qgis dev team!
The Jürgen's Karmic packages work well.
Regards,
Germán
On Sat, Jul 17, 2010 at 5:55 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Tim,
> On Sat, 17. Jul 2010 at 18:24:42 +0200, Tim Sutton wrote:
> > If you make a package please be so kind as to send me an email with
> details
> > of where I can download the package. Please make sure the package is
> > wgettable since I do not have the bandwidth to first download all
> packages to
> > my home pc and then up again to the download server.
> For Linux I updated my Launchpad ppa at [1] with packages for Ubuntu
> jaunty,
> karmic, lucid and maverick.  For some reason only the i386 packages were
> build
> and the amd64 build are still in the queue.
> For Windows I created a OSGeo4W on our QGIS VM (while access to
> upload.osgeo.org is restricted.  BTW I enabled the apache userdir module
> in the
> process.
> There are only two qgis packages left:  "qgis" is the current release 1.5
> and
> "qgis-dev" will be the nightly builds (currently not updated
> automatically).
> Both contain QGIS including python and the grass plugin in a single
> package.
> All other packages are not marked obsolete and upgrade to 1.5.  The express
> install will also install 1.5.
> he packages are available at [2]. To install from the mirror one need to
> call
> this way:
> osgeo4w-setup -s http://qgis.org/~jef/osgeo4w
> Also available is a standalone installer from the same packages at [3].
> Please test...
> Jürgen
> [1]
> https://launchpad.net/~jef-norbit/+archive/qgis-unstable-ubuntugis-jef/+packages
> [2] http://qgis.org/~jef/osgeo4w
> [3] http://qgis.org/~jef/QGIS-OSGeo4W-1.5.0-13926-Setup.exe
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
  |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100718/91797d1d/attachment.html
