[Qgis-developer] Eric4, QScintilla and QGIS
Noli Sicad nsicad at gmail.com
Thu Jul 29 06:32:11 EDT 2010
You can get PyQt4.4.3 for python2.5 from http://pyqwt.sourceforge.net/
PyQwt3D-0.1.6-Python2.5-Qt4.4.1-PyQt4.4.3-NumPy1.2.0.exe
Then try to find Qt4.4.3, this might be a better approach.
Noli.
On 7/29/10, G. Allegri <giohappy at gmail.com> wrote:
> +1. I already asked this months ago... It would be very good, also to
> have an improved Python Scripting environment in QGis.
> giovanni
> 2010/7/29 Duarte Carreira <DCarreira at edia.pt>:
>> Hi.
>> I’m trying to work with Eric4 and QGIS. Eric4 integrates very well with
>> PyQT
>> but requires QScintilla2 and its python bindings. We can get this by
>> installing PyQt [1] or by building QScintilla from scratch [2].
>> Problem is, I can’t find PyQt binaries anymore at the same version used by
>> QGIS (QT 4.5.2).
>> And no matter how hard I try I always fail to build QScintilla python
>> bindings (tried Visual Studio 2008 and mingw32; several versions of
>> Qscintilla)… problems arise at the final stage of nmaking the python
>> bindings, with several C2440 errors (Conversion loses qualifiers) [3].
>> So as a last resort I’m asking the list if anyone can help…
>> …do you have a PyQt distribution that includes QScintilla and is on par
>> with
>> QGIS? Can you build QScintilla 2.2 or 2.3 using the same QGIS/OSGeo4W
>> environment (v2.4 requires sip 4.10 and QGIS is using sip 4.8)?
>> The ideal situation would be to include Qscintilla in the  QGIS building
>> process… but this may be to much to ask?
>> Thanks,
>> Duarte
>> [1]
>> http://www.riverbankcomputing.co.uk/static/Downloads/PyQt4/PyQt-Py2.5-gpl-4.7.4-1.exe
>> [2] http://www.riverbankcomputing.co.uk/static/Docs/QScintilla2/index.html
>> [3] error C2440: 'initializing' : cannot convert f rom 'const char *' to
>> 'char *'
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
