[Qgis-developer] Re: GoogleLayers Patch 3
Ivan Mincik ivan.mincik at gista.sk
Tue Jun 1 04:49:25 EDT 2010
On Tuesday 01 June 2010, you wrote:
> Ivan,
> I make several changes in source.
> Have problem when use very call for
> "QgsCoordinateReferenceSystem.createFromProj4", creating more one CSR's
> users, i call only one this method.
> The other problem is use of "decimal point", in portuguese the signal is
> ',', i change the Proj4 string, where not have decimal point.
> I test in QGis 1.4 and QGis 1.5 (windows Xp SP 2) it run perfect, where,
> no need settings "on the fly" and change project.
> If you use this change in next version, please, include me in author.
> Luiz Motta, motta.luiz at gmail.com
> Regards,
> Luiz Motta
Hi, thanks a lot for Your work, I will look on Your patches soon.
Ivan Mincik
