[Qgis-developer] GdalTools in trunk
Giuseppe Sucameli brush.tyler at gmail.com
Fri Jun 4 07:24:55 EDT 2010
ops... from r13644 :) sorry
Regards.
On Fri, Jun 4, 2010 at 1:20 PM, Giuseppe Sucameli <brush.tyler at gmail.com>wrote:
> Fixed from r13643.
> Now every strings after the version are ignored.
> Cheers.
> On Fri, Jun 4, 2010 at 12:21 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> I guess having 'dev' in the release name is causing issues.... (see
>> below).
>> Regards
>> Tim
>> Couldn't load plugin GdalTools due an error when calling its initGui()
>> method
>> Traceback (most recent call last):
>>  File "/home/timlinux/apps/share/qgis/python/qgis/utils.py", line
>> 159, in startPlugin
>>    plugins[packageName].initGui()
>>  File
>> "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/GdalTools.py",
>> line 86, in initGui
>>    self.GdalVersion = Utils.Version( Utils.GdalConfig.version() )
>>  File
>> "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py",
>> line 347, in version
>>    return Version(gdal.VersionInfo("RELEASE_NAME"))
>>  File
>> line 613, in __init__
>>    self.vers = self.string2vers(ver)
>>  File
>> line 623, in string2vers
>>    vers[1] = int(nums[1])
>> ValueError: invalid literal for int() with base 10: '8dev'
>> Python version:
>> 2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
>> [GCC 4.4.3]
>> QGIS version:
>> 1.5.0-Trunk Trunk, 13642
>> Python path: ['/home/timlinux/apps/share/qgis/python',
>> '/home/timlinux/.qgis/python', '/home/timlinux/.qgis/python/plugins',
>> '/home/timlinux/apps/share/qgis/python/plugins',
>> '/usr/local/lib/python2.6/dist-packages/django_tinymce-1.5-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/gearman-1.5.0-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/django_simple_captcha-0.1.7-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/django_extensions-0.5-py2.6.egg',
>> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
>> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
>> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages/PIL',
>> '/usr/lib/python2.6/dist-packages/gst-0.10',
>> '/usr/lib/pymodules/python2.6',
>> '/usr/lib/python2.6/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.6/gtk-2.0',
>> '/usr/local/lib/python2.6/dist-packages',
>> u'/home/timlinux/.qgis//python/plugins',
>> '/home/timlinux/apps/share/qgis/python/plugins/fTools/tools',
>> '/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools',
>> '/home/timlinux/apps/share/qgis/python/plugins/GdalTools', '.']
>> On Fri, Jun 4, 2010 at 4:33 AM, Giuseppe Sucameli <brush.tyler at gmail.com>
>> wrote:
>> > Hi guys,
>> > now GdalTools plugin v.1.2.0 is in trunk.
>> > So, if you have to open a ticket you must use the qgis trac.
>> > For the translators: remember that you must update the translations
>> > on the qgis repository and not in the Faunalia one.
>> > Cheers.
>> > Giuseppe Sucameli
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
> Giuseppe Sucameli
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100604/7639cc09/attachment-0001.html
