[Qgis-developer] Re: [Qgis-user] Value Tool
Borys Jurgiel borysiasty at aster.pl
Thu Jun 24 01:47:31 EDT 2010
Dnia czwartek, 24 czerwca 2010 o 03:49:52 Giuseppe Sucameli napisał(a):
> Hi Giovanni,
> I find the issue. Both the folder within the zip package and the package
> must have the same name.
> @ Ghislain: you can fix it by renaming the package to valuetool.zip .
> AFAIK valuetool-0.3 isn't a valid plugin folder name.
It can be either valuetool.zip or valuetool.0.3.zip - if you want to use a
suffix, it MUST be after a dot, not a dash. The directory inside can't contain
any suffix.
