[Qgis-developer] Re: [Qgis-user] gdalbuildvrt on win7 crashes
Giovanni Manghi giovanni.manghi at gmail.com
Mon Mar 15 05:41:54 EDT 2010
> All gdal .exe tools (buildvrt, contour, rasterize,
> nearblack, warp, grid, translate, information,
> assign projection, build overviews) display this
> error, but they return also a correct result, so
> you can load the output result by adding the output
> as raster/vector layer.
> We're trying to find a solution soon.
fwtools (2.4.7) .exe tools seems to work fine under Vista/Seven.
cheers
-- Giovanni --
