[Qgis-developer] editing nodes
Micha Silver micha at arava.co.il
Mon Mar 15 06:09:57 EDT 2010
On 15/03/2010 11:53, Giovanni Manghi wrote:
> Hi,
> On Mon, 2010-03-15 at 11:47 +0200, Micha Silver wrote:
>> I find that the new arrangement for editing nodes in a polygon or line
>> feature is more difficult that before. Previously there was a set a
>> buttons for moving nodes, deleting nodes, etc. Now there's the single
>> "node tool" button. When clicking on a node, all nodes become red
>> squares, and it's not clear how to select/move/delete a single node.  A
>> second click seems to always select (change to blue color) a line
>> *segment*, i.e. two nodes. Then any action - moving, etc - applies to
>> both nodes.
>> Am I missing something? How do I select a single node?
> after having all nodes red, if you click once on a node this become
> selected (blue) (if you then press ctrl you can selected multiple
> nodes). If you click once between two nodes the segment between the
> nodes is select.
Thanks.
Often I get two nodes (line segment) selected blue instead of just the
single node. Maybe it's a snapping tolerance prob?
> It also took to me a couple of days to get used when it was introduced.
> Actually new qgis users found the node tool pretty good.
> cheers
> -- Giovanni --
> This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
