[Qgis-developer] Native file dialog bugs and the new Save As Vector functionality.
John C. Tull jctull at gmail.com
Fri Mar 19 11:53:27 EDT 2010
Hi Borys,
On OS X, the native dialog seems to do what it should. Saving a layer to an ogr format brings that same format as the default the next time you choose save as. I am not sure of other problems that you are experiencing on kde, but things seem fine on OS X.
I would recommend any change away from the native dialog be specific to kde. The non-native dialogs on OS X are very awkward and clunky. In fact, it would be great to make  an effort to bring native dialog support to all existing ui elements (native in the application as well as plugins).
Regards,
John
On Mar 19, 2010, at 6:29 AM, Borys Jurgiel wrote:
> Hi all,
> The native file dialogs in KDE 4.4 (and afair 4.3 too) seem to contain some
> bugs. The most serious bug is broken file type selector: the &selectedFilter
> pointer doesn't interact with the selector.
> It means that in all native file dialogs the file type filter is initially set always
> to the first item, ignoring the last used value stored in QSettings. But the
> new Save As Vector functionality is completely broken, as the file format
> is not fetched from the selector and the layer is always saved as Shapefile.
> Besides of that, there are also some minor but irritating bugs in the native
> version, while everything works perfectly with non-native Qt4 dialog.
> So the first suggestion is to set the non-native dialog until the bug in KDE
> is fixed:
> -  QString outputFile = QFileDialog::getSaveFileName( 0, tr( "Save layer as..." ), dirName, filterString, &selectedFilter );
> +  QString outputFile = QFileDialog::getSaveFileName( 0, tr( "Save layer as..." ), dirName, filterString, &selectedFilter, QFileDialog::DontUseNativeDialog )
> The second idea is to go further and use our custom dialog with the encoding
> field and also add a CRS selector: a field with default value (the present
> layer CRS) and a button to call the big CRS dialog only if needed.
> What do you think? Not long ago we switched to the native version in the Open
> Vector dialog, so I'm not so hurry to make an opposite change here. But in fact
> I prefer one dialog with encoding and CRS fields rather than the present sequence
> of the two dialogs.
> Qgis-developer mailing list
