[Qgis-developer] plugin's menu organization
MORREALE Jean Roc jr.morreale at enoreth.net
Mon Mar 29 05:24:39 EDT 2010
I'm not sure because if a user click on it without looking at it then he doesn't get the information and no other way to get it again (just by reinstalling it).
 Le lun 29/03/10 08:41, "Andreas Neumann" a.neumann at carto.net a écrit:
> Hi all,
> For the issue on how to find the plugin: one option would be to have a
> mini-documentation popping up after the plugin install that indicates:
> * where to find the plugin (menu, toolbar)
> * quick info how to use it
> * Link to webpage with full documentation.
> This mini documentation could be part of the plugins.xml file of the
> repository.
> What do you think?
> Andreas
> On Sun, March 28, 2010 10:45 pm, Borys Jurgiel wrote:
> >> Completely seperate plugin section, otherwise
> when you turn on a plugin
>> you'll have no idea where it is. An exception to
> this would be if the
>> Manage plugins where you go to activate them had
> tabs with the same
>> names, that would clearly indicate where you
> should find the plugin once
>> it's turned on.
> > Thanks. So clear categorization withing the existing
> plugin menu seems
> best
> > for a start.
> Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> Andreas Neumann
> http://www.carto.net/neumann/
http://www.svgopen.org/
