[Qgis-developer] ftools & merge shapes
Martin Dobias wonder.sk at gmail.com
Wed Mar 31 13:21:14 EDT 2010
On Wed, Mar 31, 2010 at 6:58 PM, Carson Farmer <carson.farmer at gmail.com> wrote:
> Hmm. On Linux, when I first applied this patch to my working copy, I
> had some trouble getting it to build/install properly. I'm not sure
> why, and I eventually got things working (can't remember how)...
> Perhaps a similar issue is cropping up here? In any case, the file is
> indeed in the src python directory in trunk, so it should be working?
I've just run across the same problem. One has to touch
python/plugins/CMakeLists.txt so that the list of python files for
installation gets updated. I've committed a dummy change r13214 that
will trigger the refresh, so that shouldn't make troubles anymore.
Martin
