[Qgis-developer] Contour plugin crashes
Chris Crook ccrook at linz.govt.nz
Wed Mar 31 13:52:47 EDT 2010
Thanks silvio
I've run this on windows XP without any problem .. I don't have Vista so can't check on that.
I guess the most likely reason is that there is some incompatibility between the DLL's of the python modules that are imported and Qgis.
Are you using OsGeo4W? And did you use that to install the missing python modules.  I have found that that distribution works for me...
Cheers
Chris
________________________________________
From: silvio.pioli at tin.it [silvio.pioli at tin.it]
Sent: 01 April 2010 03:19
To: Chris Crook; qgis-developer at lists.osgeo.org
Cc: lionel.roubeyrie at gmail.com
Subject: R: RE: [Qgis-developer] Contour plugin crashes
Ok, I'm sorry you are right.
My OS is Windows Vista Home edition. As I 've already said, the version of Qgis is 1.4.0.
And, when I said the program crashes, I meant Qgis. Qgis doesn't start, the only thing I know is I got the Windows Error Dialog with:
 "Nome evento problema:    BEX  (Name event)
  Nome applicazione:    qgis.exe  (Name application)
  Versione applicazione:    0.0.0.0 (Version)
  Timestamp applicazione:    4b4a2d91
  Nome modulo con errori:    StackHash_6e31   (Module name with errors)"
Probably the crash happens when the plugin loader try to load this particular plugin.
----Messaggio originale----
Da: ccrook at linz.govt.nz
Data: 30-mar-2010 7.53 PM
A: "silvio.pioli at tin.it"<silvio.pioli at tin.it>, "qgis-developer at lists.osgeo.org"<qgis-developer at lists.osgeo.org>
Cc: "lionel.roubeyrie at gmail.com"<lionel.roubeyrie at gmail.com>
Ogg: RE: [Qgis-developer] Contour plugin crashes
Hi Silvio
Could you give a bit more information about what platform you are using and how it crashes.
Do you mean that qgis itself crashes, or that the plugin fails to load, or that it crashes when you try to use it?  Do you get any error messages?
Thanks
Chris
From: qgis-developer-bounces at lists.osgeo.org [qgis-developer-bounces at lists.osgeo.org] On Behalf Of silvio.pioli at tin.it [silvio.pioli at tin.it]
Sent: 31 March 2010 06:00
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] Contour plugin crashes
Hello,
I just tried to download the Contour plugin from user contributed ones.
I unzipped it in the python plugins folder of QGis 1.4.0. Enceladus.
At the beginning the plugin was not loaded because "matplotlib", "shapely" e "numpy" modules were not installed.
I did it. I installed them. Now the plugin is loaded but the program crashes even before to completely start.
Any idea?
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
Thank you.
