[Qgis-developer] GoogleLayers
Alexander Bruy alexander.bruy at gmail.com
Sat May 8 12:01:00 EDT 2010
I've try GoogleLayers plugin on another Windows box and all works fine.
Maybe my problem is system specific.
On Fri, 7 May 2010 08:42:00 +0200
Ivan Mincik <ivan.mincik at gista.sk> wrote:
> Hi Alexander,
> I can do the same without any problem.
> This exception is case when there are wrong coordinate values for counting zoom level. For example, when You are very
> far from the map or in wrong coordinates.
> 1. Can You try different places and different zoom levels ?
> 2. Can You please replace line z = min(max(int(ceil(log(min(width / ((x2 - x1) * 256), height /((y2 - y1) * 256)), 2))),
> 0), 19) with z= 10 and try again ?
Alexander Bruy
