[Qgis-developer] Reverse Changeset 13499
Jeremy Palmer JPalmer at linz.govt.nz
Mon May 17 23:53:04 EDT 2010
I was wondering if it is possible to reverse https://trac.osgeo.org/qgis/changeset/13499 ?
The reasoning behind the estimated metadata option is it only gets the table row count from the table statistics, regardless of any filters.
Thanks
Jeremy
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
