[Qgis-developer] Help Needed in retrieving file path from the layer name
motta.luiz at gmail.com motta.luiz at gmail.com
Tue May 18 10:22:33 EDT 2010
Bishwarup Banerjee,
You can use the method QgsLayer.source()
I use this methods in the Spatial Query plugin:
line 382 for populate ToolTipRole item in combobox
Bishwarup Banerjee escreveu:
> Dear All,
> Is there any way to get the entire file path from the layer name?
> For example:
> A user selects a layer inside a combobox, which in turn accesses the
> map layer registry.
> Now I want to know the full path of the layer selected.
> If the layer name through combobox is "xyz"
> Then I want to get "c:/aa/bb/xyz.shp" or the exact location of the
> layer, in the harddisk.
> Any help regarding this will be highly helpful and appreciated.
> With Warm Regards,
> Sonai
> Qgis-developer mailing list
