[Qgis-developer] Minor Irritations
Jeremy Palmer JPalmer at linz.govt.nz
Wed Nov 3 16:42:54 EDT 2010
Thanks Marco.
I have attached a new patch to commit the tooltips after the freeze is over:
https://trac.osgeo.org/qgis/attachment/ticket/2938/select_tools_tooltips.diff
Cheers,
Jeremy
________________________________________
From: Marco Hugentobler [marco.hugentobler at sourcepole.ch]
Sent: Thursday, 4 November 2010 1:00 a.m.
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Minor Irritations
Ok, applied in r14497.
Marco
Am Mittwoch, 3. November 2010, um 11.57:24 schrieb Tim Sutton:
> Hi
> On Wed, Nov 3, 2010 at 12:33 PM, Borys Jurgiel <borysiasty at aster.pl> wrote:
> > Dnia środa 03 listopada 2010 o 11:25:40 Marco Hugentobler napisał(a):
> >> Thanks Jeremy, the patch looks fine.
> >> As it includes translatable strings, it might be better to hold off
> >> until code freeze / string freeze is over.
> >> Tim: what do you think?
> > I'd prefer to apply the patch except qgisapp.cpp file - this way we avoid
> > introducing the temporary behaviour to qgis 1.6 and strings will wait for
> > unfreeze.
> Yes I agree with Borys' suggestion.
> Regards
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Webereistrasse 66, 8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
