AW: [Qgis-developer] legend problems
Paolo Cavallini cavallini at faunalia.it
Thu Nov 4 12:32:34 EDT 2010
Il 03/11/2010 19:05, Andreas Neumann ha scritto:
> Can you be more specific on what the problems are? Do you have the render
> cache active or not? The render cache caused a lot of problems in the
> past, so I generally disable it.
I tried with and without the cache, but the results are similar: layers do not appear
when moved up and down, etc.
Paolo Cavallini: http://www.faunalia.it/pc
