[Qgis-developer] Raster providers
Radim Blazek radim.blazek at gmail.com
Fri Nov 5 06:17:02 EDT 2010
I appreciate your interest, but as I said, it is not usable at the moment,
with a lot of luck you can display GRASS integer map, but you have to
set min/max manually
to get reasonable colors.
Radim
On Fri, Nov 5, 2010 at 10:08 AM, G. Allegri <giohappy at gmail.com> wrote:
> Thanks Radim! That was a feature I hoped to see since the first time I
> saw Qgis :)
> I'm going to check it out rigth now.
> giovanni
> 2010/11/5 Radim Blazek <radim.blazek at gmail.com>:
>> Hi,
>> I have created new branch 'raster-providers' for true raster providers
>> support development which is my main task for the upcoming hackfest.
>> It is not yet ready for testing. I have only submitted some initial
>> work for passing data for rendering from providers to raster layer.
>> I will appreciate, if you avoid changes in raster area in this period
>> to make later merging easy. It involves especially
>> src/app/qgsrasterlayerproperties.cpp
>> src/core/raster/qgsrasterlayer.cpp
>> src/core/raster/qgsrasterlayer.h
>> src/core/raster/qgsrasterviewport.h
>> src/core/qgsrasterdataprovider.cpp
>> src/core/qgsrasterdataprovider.h
>> src/providers/grass/
>> src/providers/wms/
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
