[Qgis-developer] Errors in OS X script
John C. Tull john.tull at wildnevada.org
Mon Nov 15 11:24:04 EST 2010
Yes, -D WITH_MAPSERVER=TRUE works and no complaints from the script.
Cheers,
John
On Nov 15, 2010, at 8:07 AM, William Kyngesburye wrote:
> ... looks like the mapserver component was recently made optional, off by default.  The error is harmless, but I'll fix it to check first.
> If you want to test the mapserver, add to configuration:
> -D WITH_MAPSERVER
> On Nov 15, 2010, at 9:57 AM, John C. Tull wrote:
>> Hi William,
>> It appears that some script components in, at least, the MinSizeRel build are not working. They seem to be expecting a directory in the application bundle that is not present. The following is at the end of the 'make install' command:
>> -- Updating QGIS library paths...
>> install_name_tool: can't open file: /Applications/QGIS.app/Contents/MacOS/fcgi-bin/qgis_mapserv.fcgi (No such file or directory)
>> My cmake command is this:
>> cmake -D CMAKE_INSTALL_PREFIX=/Applications -D CMAKE_BUILD_TYPE=Release -D CMAKE_BUILD_TYPE=MinSizeRel -D WITH_INTERNAL_SPATIALITE=FALSE ..
>> Cheers,
>> John_______________________________________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
