[Qgis-developer] Python Plugin Repository
Alex Mandel tech_dev at wildintellect.com
Wed Nov 17 11:52:39 EST 2010
On 11/17/2010 06:59 AM, Alessandro Pasotti wrote:
> 2010/11/17 Tim Sutton <lists at linfiniti.com>
>> Hi (plugin repo) devs
>> I have committed a basic django project (it as yet contains no apps)
>> along with readme license, installation guide etc. Its ready for you
>> to start building your apps underneath it.
>> https://github.com/qgis/qgis-django
>> I was thinking along the lines of having three apps:
>> plugins
>> usermap
>> certification
>> i.e. please dont hardwire templates etc. around just the concept of
>> the plugin repo as we will also develop other functionality within the
>> same project.
>> Regards
> Hi,
> I need to put into focus the requirements of this project, a couple of
> questions before start writing code:
> * should we use this page http://www.qgis.org/wiki/PluginRepository for
> specs or directly put them on github ?
> * a DB dump of the the actual Repository application would be helpful, how
> can we obtain it ?
> * who wrote the actual application ? Can we get some guidance from the
> original author (hints, common pitfalls etc.) ?
> * what is the purpose of the "certification" app ?
> * since there is a "usermap" application, can we rely on postgis (is it
> available) on the server ?
> Thanks!
Yes Postgis can be made available on the server, are we sure the load is
high enough to warrant it over Spatialite? I can't recall if we moved
the Joomla backend to Postgres, if we did then +1 to add postgis to it.
If we are still using Mysql then we might want to try keeping the load
lower with Spatialite.
I believe Gary wrote the previous app and has it hosted on his servers,
so we'll need to ask him for the dump(hopefully he sees this).
Thanks,
Alex
