[Qgis-developer] manageR plugin: hot wo load R package "sp"
"Peter Löwe" peter.loewe at gmx.de
Mon Nov 22 03:49:02 EST 2010
Hi Carson,
the dataset is the standard Spearfish sample dataset (http://grass.fbk.eu/sampledata/spearfish_grass60data-0.3.tar.gz)[data layers used: archsites (point), streams (line), quads (polygon)].
I am using QGIS 1.6.0 (similar effects were observed in QGIS 1.4). "Reprojection on the fly" is active, using EPSG:4326 as reference SRS.
Here's a transcript from the shell output:
/localhome/> qgis
Python support ENABLED :-)
Loaded : Python Batch Processing  (package: pybatchproc)
Loaded : DPSimplify (package: dpsimplify)
Loaded : Load wktRaster to QGIS (package: wktraster)
Loaded : Mirror Map Plugin (package: mirrormap)
Loaded : Geoprocessing (package: geoprocessing)
Loaded : Merge shapes (package: mergeshapes)
Loaded : Geocoding (package: GeoCoding)
Loaded : Load Them All (package: loadthemall)
Loaded : TopoColour (package: topocolour)
Warning: QHttp: empty path requested is invalid -- using '/'
Loaded : Plugin Installer (package: plugin_installer)
Loaded : Google Layers (package: GoogleLayers)
Loaded : RGB Composition Plugin (package: rgb)
Loaded : QGISRest plugin (package: qgisrest)
Loaded : manageR (package: manageR)
Loaded : Closest Feature Finder (package: ClosestFeatureFinder)
Loaded : Click-fu (package: clickfu)
Loaded : SRTM elevation importer for Qgis (package: qgissrtm)
Loaded : fTools (package: fTools)
 100%
 100%
 100%
Segmentation fault
It seems like the segfaulting occurs independent from the geometry type of the layers, but occurs when a _second_ layer is imported into manageR.
Peter
-------- Original-Nachricht --------
> Datum: Fri, 19 Nov 2010 14:42:32 +0000
> Von: Carson Farmer <carson.farmer at gmail.com>
> An: "Peter Löwe" <peter.loewe at gmx.de>
> CC: qgis-developer at lists.osgeo.org
> Betreff: Re: [Qgis-developer] manageR plugin: hot wo load R package "sp"
> Hi Peter, would it be possible for you to send me an example of the
> dataset that causes the crash?
> Carson
> On 19 November 2010 14:25, "Peter Löwe" <peter.loewe at gmx.de> wrote:
> > Hi Barry,
> > after having R-dev installed, getting sp works like a charm:
> > install.packages("sp")
> > library(sp)
> > does the trick.
> > Using "Import Layer From Canvas" works for point and line layers (tested
> on the Spearfish dataset)
> > However, applying "Import Layer From Canvas" for polygon layers leads to
> a segfault.
> > Any Suggestions ?
> > Peter
> >> Datum: Fri, 19 Nov 2010 09:39:17 +0000
> >> Von: Barry Rowlingson <b.rowlingson at lancaster.ac.uk>
> >> An: peter.loewe at gmx.de
> "sp"
> >> On Fri, Nov 19, 2010 at 8:26 AM,  <peter.loewe at gmx.de> wrote:
> >> > Hi List,
> >> > the manageR plugin requires for the action "Import Layer From Canvas"
> >> the R package "sp".
> >> > The common way to install sp within the manageR CLI fails:
> >> > Installing package(s) into
> >> ‘/home/pel/R/x86_64-unknown-linux-gnu-library/2.12’
> >> > (as ‘lib’ is unspecified)
> >> > --- Please select a CRAN mirror for use in this session ---
> >> > Loading Tcl/Tk interface ... done
> >> > trying URL
> 'http://cran.at.r-project.org/src/contrib/sp_0.9-72.tar.gz'
> >> > Content type 'application/x-gzip' length 535353 bytes (522 Kb)
> >> > opened URL
> >> > downloaded 522 Kb
> >> > The downloaded packages are in
> >> >        ‘/tmp/RtmpOTaSDB/downloaded_packages’
> >> > Warning message:
> >> > In install.packages("sp") :
> >> >  installation of package 'sp' had non-zero exit status
> >> > Does anybody know a way to solve this one ?
> >>  What happens when you try this from the R command line from a
> >> terminal window, rather than manageR? Possibly manageR is hiding some
> >> diagnostic messages.
> >>  Since sp is being installed from source, my first suspicion is that
> >> you don't have the requisite C/Fortran compilers on your system. Is it
> >> ubuntu/apt-based? Do "sudo apt-get install build-essential" from a
> >> command line, that should get them.
> >> Barry
> > Dr. Peter Löwe
> > GMX DSL Doppel-Flat ab 19,99 &euro;/mtl.! Jetzt auch mit
> > gratis Notebook-Flat! http://portal.gmx.net/de/go/dsl
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation
> National University of Ireland, Maynooth,
> http://www.carsonfarmer.com/
Dr. Peter Löwe
