[Qgis-developer] QGIS for winXP
rafael.mejias at sinfogeo.com rafael.mejias at sinfogeo.com
Mon Nov 22 14:56:20 EST 2010
Thanks Jürgen, but I got error in the same point before:
1>------ Build started: Project: qgis_core, Configuration: Debug Win32
2>------ Build started: Project: pluginstaller, Configuration: Debug
Win32 ------
2>Generating ui_qgsplugininstalleroldreposbase.py
1>Generating qgssearchstringparser.cpp
1>C:\Archivos de programa\GnuWin32\bin\bison.exe: m4: Invalid argument
1>Project : error PRJ0019: A tool returned an error code from
"Generating qgssearchstringparser.cpp"
1>Build log was saved at
"file://c:\QGIS\build\src\core\qgis_core.dir\Debug\BuildLog.htm"
1>qgis_core - 1 error(s), 0 warning(s)
Yes, the notes are:
[1]http://www.qgis.org/wiki/Building_QGIS_from_Source#4._Building_on_Windows
Thanks you,
Rafa
El 22/11/2010 18:08, Jürgen E. Fischer escribió:
> Hi Rafael,
> On Mon, 22. Nov 2010 at 17:40:39 +0100, rafael.mejias at sinfogeo.com wrote:
>>     I've been trying to build QGIS with VC++ 2008 Express and I'm following
>>     the notes [1], but when I build QGIS using the ALL_BUILD target, I always
>>     get this error:
>> |3>Generating qgssearchstringparser.cpp                                         |
>> |3>C:\Archivos de programa\GnuWin32\bin\bison.exe: m4: Invalid argument         |
> Add %PROGRAMFILES%\GnuWin32\bin to your PATH.
> Are the notes you mentioned the installation guide[1] or are you refering to
> something else?
> Jürgen
> [1] http://www.qgis.org/wiki/Installation_Guide
    *Rafael Fernández Mejías*
    www.sinfogeo.com
    Tel. 91 642 53 61 - Fax 91 350 14 23
    www.sinfogeo.es <http://www.sinfogeo.es>
Antes de imprimir este correo piense si es realmente necesario.
Este mensaje se dirige exclusivamente a su destinatario y puede contener
información confidencial sometida a secreto profesional o cuya
divulgación esté prohibida en virtud de la legislación vigente.
Cualquier opinión en él contenida es exclusiva de su autor y no
representa necesariamente la opinión de la empresa. Si ha recibido este
mensaje por error, le rogamos nos lo comunique inmediatamente por esta
misma vía y proceda a su destrucción.
This message is intended exclusively for its addressee and may contain
information that is CONFIDENTIAL and protected by professional privilege
or whose spreading is prohibited by virtue of the in force legislation.
Any opinion there in contained is solely that of the author and does not
represent necessarily the opinion of the company. If this message has
been received in error, please immediately notify us via e-mail and
delete it.
Skipped content of type multipart/related
