[Qgis-developer] QGIS for winXP
rafael.mejias at sinfogeo.com rafael.mejias at sinfogeo.com
Tue Nov 23 06:08:40 EST 2010
Hi Giuseppe, it's true that the paths in windows are a problem. This
afternoon, I'll trying your suggestion and later I will write to the
list with my experience.
Thanks,
Rafa
El 23/11/2010 0:23, Giuseppe Sucameli escribió:
> Hi Rafael,
> On Mon, Nov 22, 2010 at 8:56 PM, rafael.mejias at sinfogeo.com
> <mailto:rafael.mejias at sinfogeo.com> <rafael.mejias at sinfogeo.com
> <mailto:rafael.mejias at sinfogeo.com>> wrote:
>     1>Generating qgssearchstringparser.cpp
>     1>C:\Archivos de programa\GnuWin32\bin\bison.exe: m4: Invalid argument
>     1>Project : error PRJ0019: A tool returned an error code from
>     "Generating qgssearchstringparser.cpp"
>     1>Build log was saved at
>     "file://c:\QGIS\build\src\core\qgis_core.dir\Debug\BuildLog.htm"
> I think the log could help us to find the issue. Send us the BuildLog
> please.
> BTW, I remember I got the same error on 14 Nov (at the HF) and I fixed
> it reinstalling
> bison e flex to C:\GnuWin32.
> I think the problem is related to the spaces within the path "Archivos
> de programa"
> ("Program files" in my case).
> Cheers.
>     El 22/11/2010 18:08, Jürgen E. Fischer escribió:
>>     Hi Rafael,
>>     On Mon, 22. Nov 2010 at 17:40:39 +0100,rafael.mejias at sinfogeo.com  <mailto:rafael.mejias at sinfogeo.com>  wrote:
>>>         I've been trying to build QGIS with VC++ 2008 Express and I'm following
>>>         the notes [1], but when I build QGIS using the ALL_BUILD target, I always
>>>         get this error:
>>>     |3>Generating qgssearchstringparser.cpp                                         |
>>>     |3>C:\Archivos de programa\GnuWin32\bin\bison.exe: m4: Invalid argument         |
>>     Add %PROGRAMFILES%\GnuWin32\bin to your PATH.
>>     Are the notes you mentioned the installation guide[1] or are you refering to
>>     something else?
>>     Jürgen
>>     [1]http://www.qgis.org/wiki/Installation_Guide
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101123/832ef282/attachment.html
