[Qgis-developer] 2 doubts prior Compiling QGIS on ubuntu 10.04 LTS
Jürgen E. Fischer jef at norbit.de
Tue Nov 23 06:07:11 EST 2010
Hi Agus,
On Tue, 23. Nov 2010 at 11:36:46 +0100, Agustin Lobo wrote:
> 1. I have grass installed from binaries. Do I need to compile it or
> can the new qgis just use the version I have installed (from
> binaries)?
If you compile you also specify where you GRASS lives.  You should point it to
the GRASS you intent to use.
> 2. I want to keep my current stable version from binaries. I
> understand that after doing
> sudo make install
Point CMAKE_INSTALL_PREFIX to an other directory than /usr (/usr/local or
~/apps) for instance).   That way you can have the packages version in the
usual location and your own build somewhere else.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
