[Qgis-developer] compile from source qgis 1.6
Alex Mandel
tech_dev at wildintellect.com
Wed Nov 24 01:18:24 EST 2010
On 11/23/2010 09:00 PM, sunil wrote:
> hi
> i have compiled qgis 1.6 from the source using msys,mingw compiler,and with
> other supported dependencies
> and then i have created a qgis 1.6.setup.exe using nsis installer , when i
> run that exe in my local machine which is having windows xp , that qgis
> interface contains plugin installer
> but when i copied that exe to other xp machines
> that qgis1.6.0 interface doesnot have plugin installer , can u suggest any
> idea? or whether any dependencies are missing?
> regards
> sunil
The plugin installer is actually a python plugin too. So if you didn't
copy the python folder inside your installation it will be missing.
See if you can find the plugin_installer folder somewhere on your system.
That's my best guess.
Thanks,
Alex
